Extruding to coordinates
nathan_degusseme
nathan_degusseme
hello,
I am trying to design rollercoaster parts in inventor to make an entire track.
But these pieces of track need supports. I am kinda stuck how i can make those supports because i want them all to end at the same level. Is it possible to extrude the support sketch to a level with coordinates x=... and y=0?
I imported a spline from another program to make the tracks and these splines have coordinates well above y=0. So if i could export the supports to y=0 they would all be automatically at the same level. (I'm going to 3D print those parts ;))
johnsonshiue
Hi Nathan,
Inventor Extrude feature does allow you to pick a point (terminating to a point). Just click the To button in the Extrude panel and select a point (2D/3D sketch point or workpoint or a vertex on a model). Would it work for you?
Many thanks!
Software Test Engineer
NigelHay
Sounds like you need to create a set of support legs which all end on the same piece of level ground. Could you create a work plane to represent the ground then select the plane as your 'extrude to' level?
