Hi, I was tracing the outline of an image and made this sketch:
When I go to extrude this sketch, it lets me select the profile. But the extrusion doesn't make a body
(After extrusion is an empty screen; no bodies were created as expected)
How can I fix this issue so that I can extrude the sketch? Thanks!
Solved by mcgyvr. Go to Solution.
You have a self-intersecting loop near the front bumper in this area.. Fix that and it extrudes just fine.
@Lucas.dolinarVFXZU wrote:
Hi, is there a standard workflow for detecting these?
Not a good one that I'm aware of.. I just zoom in and pan around till I find it.. I suppose you could add geometry to fence off certain areas to limit you down to certain zones or other similar tricks like that..
Whenever an Extrude does not automatically highlight a profile area - switch to Surface output.
Error is identified - just need to locate the self-intersection...
The Extrude was showing with arrow the selected profile... (loop)...
