I have searched and not found any answers to what I am trying to do.
As per the attached part, I inserted an image on the top surface of the tile. What I would like to do is have the extruded cut go through the image so that the image appears to be chamfered. Is this even possible?
If so I welcome the tricks that would allow this to be done.
Solved by pcrawley. Go to Solution.
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
So you'd like the tile image to be cut off by the extrusion?
Use "Decal" and use the image you've already created in the sketch:
