Inventor Forum
Extrude so that end gets thinner
4 REPLIES 4
627 Views, 4 Replies
I'm using the extrude tool so that the rectangle that I'm extruding (downwards) will taper (and become thinner at the bottom). However, when I do this, even as a fraction (.01) it seems to get bigger at the bottom. How do I make it thinner at the bottom, not bigger? Thanks.
Tags (2)
4 REPLIES 4
mpatchus
Enter a negative value.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
in reply to: mpatchus
That worked well, but how do I taper only the width of the recetange, not the length?
mpatchus
Taper will apply to the entire shape.
To do something like what you are stating, I'd suggest using a Loft with two defined sketches, as shown below.
Inventor 2025 Beta
Yijiang.Cai
Please try the face draft after extrude. First you could create extrusion without tap, then add face draft.
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
