Inventor Forum
extrude fails on 3d modelling
4 REPLIES 4
351 Views, 4 Replies
generated a length of angle iron using frame generator and now trying to model flatbar welded to in, however, inventor fails to generate solid from my rectangle sketch, even though it picks up the shape Im wanting to extrude,
4 REPLIES 4
swalton
Please post your part, (or a dummy with the same problem) and Inventor option.  It is easier for forum members to help if they have access to the native Inventor files.
Design intent question: Why are you extruding this flat bar in a angle iron part?  I would normally do this as two separate part files, then combine in an assembly file.
Steve Walton
Inventor 2023
Vault Professional 2023
SBix26
It appears that you're trying to create this extrusion in an assembly file, not in a part file.  Assembly extrusions can only remove material, not create material.  You will need to create a new part, create a sketch, then extrude it.  Then place it in your assembly and constrain it to the angle.
Sam B
Inventor Pro 2020.1 | Windows 7 SP1
LinkedIn
in reply to: swalton
I find it faster to simply add a sketch and extrude it than generate a second component, save, import, join, and resave.
in reply to: SBix26
ok, that clears up my issue. Thanks
Technology Administrators
