PFA
model is scanned by 3d scanner and then converted to .stl and then .ipt
i have drawn rectangle above object which need to extrude cut from object
any way to do this?
2015/2016 doesn't like the mesh ... need to convert the mesh to solid
try the mesh enabler
google of some solutions
You have an open mesh - so this is not going to work.
Your scanner software should be able to do this.
What scanner are you using?
I have a Sense scanner.
The software that you download from their website will close the open areas of the scan.
You need to do this before bringing into Inventor.
You need a relatively "clean" mesh for the meshenabler to work.
You would have to do a lot of cleaning up of that mesh in the Sense software.
Can your scanner output in any other format (.sat, .iges, .step)? I'd try that. I always seem to have the most problems w/ .stl files.
Can you zip and attach your original stl or obj file here?
I've been experimenting a bit on this type of work today and might be able to find time tomorrow to work up a video using your file.
