HELLO FRIENDS;
CAN ANYONE GIVE ME AN ORIENTATION ON THE BEST WAY TO EXTRUDE A PIECE WITH AN ANGLE OF 70º IN THE DIRECTION OF THE RED ARROWS?
Solved by SBix26. Go to Solution.
Hi! Or, Ruled Surface. You can select the edges and set a protruding direction (parallel to the frame). Lastly, thicken the surface as a solid.
Many thanks!
