Inventor Forum
Extrude & Taper Angle
14 REPLIES 14
Message 1 of 15
BryanKelley
3831 Views, 14 Replies
BryanKelley
Hello Everyone,
  I would like to know how often people use the Taper option when using the Extrude feature.
Bryan
Sr. Software QA Engineer
DLS – Mechanical Design
Hello Everyone,
Bryan
Tags (2)
14 REPLIES 14
Message 2 of 15
yefengjiang
in reply to: BryanKelley
yefengjiang
As I know, Inventor has CIP data gathered from users to indicate if some functionalities are used. And for Extrude command, there is one attribute in CIP data is designed to show if user has used taper (either regular or asymmetric) in his extrusion creation.
However, I think the CIP data is offical information, and we cannot get it directly. So, if you want get the detailed information, you can contact the CIP owners.
Message 3 of 15
SBix26
SBix26
Very rarely, less than 1% of times that I use the Extrude tool.  I typically prefer to add a draft feature so it's easier for others (and me!) to follow, but there are times when the taper option makes things much simpler.
Message 4 of 15
mcgyvr
in reply to: SBix26
mcgyvr
.0001% max... I also use draft instead.
Message 5 of 15
rdyson
rdyson
Often, maybe as much as 5 - 10%. I also use draft quite a lot. I do plastic parts primarily.
And the heads up display arrow thingy, absolutely never. Totally user unfriendly, in my opinion.
PDSU 2016
PDSU 2016
Message 6 of 15
I use it more times than not.  I've been p'd off ever since it was moved to the "More" tab. Smiley Mad
Message 7 of 15
More lately than I had previously and probably quite a bit going forward as I'm working with more and more cast parts.
I estimate 5-10% of my extrudes are tapered.
Message 8 of 15
I use it quite often as many parts I design are cut on EDMs.
Message 9 of 15
BryanKelley
in reply to: SBix26
BryanKelley
Thank you Sam.
Bryan
Thank you Sam.
Bryan
Message 10 of 15
BryanKelley
in reply to: mcgyvr
BryanKelley
Thanks McGyver
Bryan
Thanks McGyver
Bryan
Message 11 of 15
BryanKelley
in reply to: rdyson
BryanKelley
Thanks.  Is this Ray Dyson btw?
Bryan
Bryan
Message 12 of 15
BryanKelley
BryanKelley
Thanks Michael.
Bryan
Thanks Michael.
Bryan
Message 13 of 15
BryanKelley
BryanKelley
Thanks Mikah
Bryan
Thanks Mikah
Bryan
Message 14 of 15
BryanKelley
BryanKelley
Thanks Vlad.
Bryan
Thanks Vlad.
Bryan
Message 15 of 15
rdyson
rdyson
Yep, that would be me.
Never bothered to change my login name here.
PDSU 2016
PDSU 2016
