Announcements
extracting DXF shape from PDF photo
yefimv
yefimv
Hello,I have the following photo taken from the attached datasheet.
This phot below is with measures  described in the table.
Is there a way to create a DXF of the shape below?
Thanks.
Replies (9)
blandb
Sketch the profile based on the dims, face it out to sheet thickness, then right click on the front face and export face as > DXF.
Autodesk Certified Professional
mikegreslick6607
You could also try PDF Import in AutoCAD and the scale appropriately.  However, I tend to agree with the above; I'd just sketch it myself. It's not that difficult of geometry.
blandb
plus, you can put in the intelligence to make ALL variations via an ipart and then publish to CC for future use as well.
yefimv
Hello, I have made a sketch as shown below.
how do i export the sketxh into dxf file.
It will be great if you could show it in video.
Thanks.
mikegreslick6607
This is relatively simple and doesn't require a video.  All that you have to do it right click on the sketch in the model browser and hit "Export Sketch As".
James_Willo
Unfortunately the image is a raster image so you cannot extract the profile. Adobe Illustrator can have a go at turning it into vector lines, but it probably wont be good enough for CAD.
James W
Inventor UX Designer
blandb
IF you are looking for just a sketch, why not do it in acad? Yes, you can't import the PDF, but you could of brought in an image. Are you making this for a 1 time use and doing it for a specific size, or are you making this parametric to where you can do different sizes of the same layout? I opened you sketch and just went to pull a dimension and the top 2 sides are not even parallel, and the lower left is missing a line completely. Actually there are multiple lines not horizontal or vertical. Plus the sketch is not fully defined as there are 71 constraints needed to fully define your sketch. You may want to re-evaluate the sketch and clean it up as the DXF will not have straight lines, unless that doesn't matter.
Please see attached for a quick variation of your part (2024)
yefimv
Hello, I have created the following sketch of other shape.
I need its DXF from the curve.
when i right click there is no export dxf menu.
what do i need to do?
Thanks.
James_Willo
Hi, it looks like you have two sketches selected, please try with just one.
James W
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
