Changing the original/base color of a published structural shape
mmatanlevi
mmatanlevi
Let's say I published a certain structural shape (profile) to the content center to use it as a frame. Before the publish, I set the material and the color, so when I insert the frame, the defult material and color would be set as the original structural shape that published. I know I can change the frame color and material in the insert frame box, but I wonder if I can change te color (or material) of the published structural shape in the content center (In such a way that it will update what need to be update).
Thank you very much in advance
James_Willo
Hi, in the CC editor, in family table editor, create a column with the appearance in that you want.
Right click the column and choose column properties and set it to member.color.
You can also place something from CC as 'custom' (on the place dialogue), change the appearance and save.
Next right click the item in CC and choose 'replace from template.' Select the item on disk that you just saved with a different appearance.
James W
Inventor UX Designer
mmatanlevi
Thank you. I didnt really understand what the column is and how I use it.
This is what I have done:
must say I didnt really know what im doing and how to define the specific color I want.
Im sure it a gap in my understanding and not in your solution. But I just want to clarify it again - my goal is that when I insert a frame, the frame member would be in specific color that I defined in advance. for example if I have two published structural shapes, lets say X and Y, I want that automatically when I insert X it get his color (lets say - green) and when I insert Y it get his color (lets say red).
thanks again
James_Willo
If you want a different colour for each member, this is the way to do it yes. the table will drive the appearance, you'll just have to refresh any members that have already been placed as the part will be saved with the old appearance.
You'll have to make sure as well that the appearance name perfectly matches the appearance name colour and that it's available when you place.
Your 'expression' should be the name of the appearance though. You can Type your appearance in this box, or uncheck it if you want a different appearance for each line.
James W
James_Willo
If everything in one family has the same colour, it would be easier to just do the replace template method.
James W
James_Willo
Step 5 on here is change the appearance
Step 12 should be the last step for you
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Replacing-Family-T...
James W
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
