Hi everyone, hope you're well.
I'm trying to create a iFeature that will have different variables, but one of the parameters that would change would be the "Small Hole Amount" (Parameters name is "SMA").
The feature is to create a flange detail of different sizes of flanges we work with, and the bigger the "Center Hole" (Parameter name is "CHS") the more Small holes there will be on the sides to clamp it together.
The problem is that all the sizes I want to change do pop up on the Extract iFeature menu, except the SHA parameter.
Can someone explain why this might not be working, or what I'm doing wrong?
The feature I made is made up of jut 1 sketch, the center hole, the small hole and then that small holes are a circular pattern within that same sketch.
(Linked a few pictures on this as well for better understanding)
