Inventor Forum
Extension Spring
8 REPLIES 8
Message 1 of 9
morini
746 Views, 8 Replies
Extension Spring
I want to know if there is any possibility to have this extension spring adaptive?
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: morini
I am sure it could be (if modeled correctly) - but it would be far easier to Animate a Parameter in Inventor Studio.
Can you explain your design intent?
Do you really need to drag with mouse, or would Studio animation suffice?
Message 3 of 9
CCarreiras
in reply to: morini
Hi!
You will find tons of examples in this forum, just search for spring.
http://forums.autodesk.com/t5/Inventor-General/How-to-make-a-spring-move/m-p/5130626#M513968
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 4 of 9
CCarreiras
in reply to: morini
Hi!
Yes, is possible.
CCarreiras
Message 5 of 9
pcrawley
in reply to: CCarreiras
Love your response CarlosC 🙂
And if the OP had written "I want to know if there is any possibility to have this extension spring adaptive and if so, how?" - would your answer have been slightly more than "Yes, is possible." ?
Peter
Message 6 of 9
CCarreiras
in reply to: pcrawley
Hi!
Of course!!! There's a link above to show how!!! There's tons of post about it!!
CCarreiras
Message 7 of 9
morini
Thanks for the reply. The problem is that I have not generate the extension spring with the "extension spring component generator". I draw a spring and than I draw the two edges, because with the component generator I never got the spring I wanted.
Message 8 of 9
CCarreiras
in reply to: morini
Hi!
Look again the images... there's a "custom" spring, modeled with a 3D coil and a Sweep, with some more features in the start and end (like yours)
With a component generator you can´t have this "adaptative spring.
CCarreiras
Message 9 of 9
morini
Sorry because I never use component generator I didn' know it was not generate by component generator.
