Hi
Please see the attached image and PART FILE, I tried to extend the line ( red circled ) towards left down corner, but couldn't . What could be the reason ?
Rgds
Hi, The reason is that it was created with a linear pattern of sketch entity, and can not modify the arc because it would no longer be the same as the initial arc.
Suggestion: As far as possible, avoid the use of circular and linear patterns in the sketches. If you visualize a linear or circular pattern try to visualize it as a pattern of operations, first imagine a cut in a solid, and then a linear pattern of the cut over the solid.
The patterns of operations are very safe, they are updated without problems.
On the other hand, the patterns of sketch entities can give many headaches when they need to make a modification in the design. For example if you need a linear pattern of 10 arcs, and the seventh needs to eliminate it, from the sketch you will have big headaches, instead if you make a pattern of cylindrical solids and then with eliminating face, you eliminate instance 7, then combine Cutting can reach its shape without problems.
I hope I have been clear and can you solve your problem. regards
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Hi Guys,
Sketch Pattern helps populate sketch geometry quickly. However, the patterned geometry has to obey the source geometry and its constraints, which can lead to confusing behaviors. Another option is to turn off Associative option. When you create the sketch pattern, expand the dialog -> uncheck "Associative." The resultant pattern will be free geometry allowing you to edit however you like.
Many thanks!
