extend part in frame generator
ggtoutounji
ggtoutounji
I have created parts in frame generator. How can i extend or trim or else to have the square tubing extended to the outside of the round flat bar? attached picture.
Curtis_Waguespack
HI @ggtoutounji ,
It looks like the Trim/Extend to Face tool would be the correct tool in this case:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
I hope this helps.
Curtis
ggtoutounji
I was not able to pick the outer round face of the flat bar.
Thanks.
JDMather
Looks like a curved bar to me.
You will most likely have to use the Copy Object functionality to get the face of the bar.
If you Attach the two parts and assembly file here - I can demonstrate the technique.
Edit the tube frame member in the context of the assembly>
Copy Object as surface body the face of the bar.
Use this surface to direct edit the tube.
eng.co
Maybe this
2020 Autodesk Product Design Suite Premium
Windows 10 Pro
INTEL Core i7-8700K 6-Core 3.7GHz (4.7GHz) Box
32 GB RAM
NVIDIA GeForce GTX 1660 Ti
ggtoutounji
Thank you, both. I will try to attach the files here. I tried to use Pack and Go but not sure if it worked well. Beside the issue of the first curve, there is an issue with the second one.
Thanks.
