Exporting mesh from FEA environment
francesco.dinh
francesco.dinh
I've created a mesh in the FEA environment that I would like to export to STL.
This is what my current mesh looks like:
When I go to save as > stl file, the output mesh is this:
Is there a way to save my particular mesh to file?
Thanks in advance.
Xun.Zhang
Hello @francesco.dinh,
Try to modify the option when exporting stl file, select the High resolution and modify the Surface deviation may help you a little bit.
Hope it helps!
Xun
francesco.dinh
Thanks! This is more or less ok but it doesn't let me correctly discretize the surface in some specific surfaces, if I understand correctly. Would there be a method to just export the FEA mesh?
Xun.Zhang
Hi! Unfortunately, Inventor FEA does not allow the resultant mesh to be exported. You will need to use Autodesk NASTRAN In-CAD to export it.
You can navigate to below post for more information as well.
https://forums.autodesk.com/t5/inventor-forum/exporting-deformed-shape-after-fea/td-p/7971484
Hope it helps!
Xun
francesco.dinh
Ok, thanks!
