Exporting From the Autodesk space to a graphic design space
Hello All,
I am seeking a more efficient workflow from going from Inventor to a vector graphic design software. One that hopefully maintains metadata for possible automation of task.
My current workflow starts with either receiving Inventor assembly(.iam) files from my engineering department. I then either create a presentation file and blow the assembly apart or (using a copy) blow apart the assembly within the .iam file. I then create an inventor drawing file with the views of the assembly I want and save as a (AutoCad.dwg) file. This file is imported into Corel Designer (I am sure you could do this with Adobe Illustrator as well).
The problem is that when the file is imported It is just a single grouping of thousands of lines with no metadata. I have found a video off an add on package to Corel that could simplify this process and possibly maintain metadata.
Does anyone have a better solution?
Thank you for any help.
