Inventor Forum
Exporting Flat Pattern to STEP FILE
9 REPLIES 9
Message 1 of 10
6895 Views, 9 Replies
HI Forum,
I am a fusion360 User.  I am using inventor  for its sheet metal function. The program works great and does what I want it to do; but  I am having trouble converting the flat model to a step or 3d model as Fusion360 generates its CNC/ CAM profiles from a 3d MODEL.
I know I can export it to a DXF and extrude it but that is doubling up the work.
Any suggestions will be appreciated.
Thank you!
-Bjorn
HI Forum,
Thank you!
-Bjorn
9 REPLIES 9
Message 2 of 10
mcgyvr
mcgyvr
Use the "unfold" feature to unfold all the bends then save copy as step file
Message 3 of 10
TheCADWhisperer
TheCADWhisperer
You can save as a 3D model (*.sat) by right clicking on the Flat Pattern node in the browser - rather than right clicking on the part face.
Fusion will open this 3D file by File>New Design from File...
Message 4 of 10
mcgyvr
in reply to: TheCADWhisperer
mcgyvr
@TheCADWhisperer wrote:
You can save as a 3D model by right clicking on the Flat Pattern node in the browser - rather than right clicking on the part face.
That only gives "SAT/DWG/DXF" options
Message 5 of 10
in reply to: mcgyvr
Works Perfectly!
Works Perfectly!
Message 6 of 10
TheCADWhisperer
TheCADWhisperer
@Anonymous wrote:
.... the flat model to a step or 3d model as Fusion360
Save as SAT solid body from Inventor worked for me.
Message 7 of 10
The problem I had was when I turned it into a "flat Pattern" rather than unfolding it.
In a flat pattern im only able to save that out as a DWG , DXF and SAT.  But If I unfold it it will save it as a step "flattened".
Thanks !
-Bjorn
Thanks !
-Bjorn
Message 8 of 10
TheCADWhisperer
TheCADWhisperer
I did not use Unfold.
I specifically stated:
Right click on the Flat Pattern node and save as a solid (*.sat ACIS file).
I can open that 3D model directly in Fusion (as indicated in the image that I attached).
Message 9 of 10
mcgyvr
mcgyvr
Yes... the SAT format does allow 3d geometry to be transferred between programs.. It will work too without the need to unfold..
Message 10 of 10
FProcp
FProcp
We have a Plasma/Oxy Plate cutting machine and I export dxf's from Inventor for cutting on it.
The Plate Cutter reads dxf's and also reads Step files but will NOT read Sat files.
The nice thing about bringing Step files into the Plate Cutter is it knows the thickness of the plate and I don't have to manually set it. It would be nice to use Step files from Inventor.
I wish Inventor could do a "Save Copy As" from the flat pattern to a "Step file".
Franco
GMT +08:00
Franco
GMT +08:00
