Exporting an assembly drawing package in diff. files - dwg and pdf
jtrivediYLEZX
jtrivediYLEZX
I have a question regarding exporting dwgs. Is it possible to export a full dwg package of an assembly (weldment) with its sub parts using one option (using Python or something if not default available). Please see example below
I have a weldement A with 2 sub parts (A1 & A2) welding together in the assembly A. when I am exporting inventor dwgs to AutoCad dwgs, I have open each component dwg (for this example, there will be three - weldement dwg and individual part dwgs) and then export it to autocad dwg. I want to know if there is or can be a single option using which I can just export all three dwgs together in a folder?
Please let me know if some one has any idea how i can approach towards solving this as it will greatly solve my time saving problem.
Gabriel_Watson
Use the Inventor Task Scheduler under Start Menu > All Apps > Autodesk Inventor.
Create Task > Export Files > Add files and/or folders.
Same for PDF with: Create Task > Print Files > add files/folders then select Options > pick your PDF printer selection.
NigelHay
Drawing Porter, free from the AutoDesk app store does this. From an assembly file it finds all of the sub-parts then lets you export as drawings or models. It also list any parts that it can't find drawings for.
jtrivediYLEZX
where does the dwgs get exported to after clicking export?
NigelHay
Anywhere you like, you can specify a folder to receive the files.
