Exporting an assembly as a dumb solid w/ no internal structure for 3D Printing
steveh3
Advisor Advisor
steveh3
Gang...I have a hand control which I am attempting to 3D print but struggling w/ finding the best method. All I care is the outside envolope w/ the internals being replaced with a solid. Just need to get the feel and aesthetics of the control. We have access to Fusion as well.
If the internal is a solid, I can control the density of the print thru the slicer for the 3D Printer.
Tried the Simply commands (Fill Voids, Define Envolopes) nothing seems to work. Am I missing something?
Thank you in advance,
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Accepted solutions (3)
kacper.suchomski
Hi
Use Simplify tool.
Kacper Suchomski
andrewdroth
I believe you are looking for the Simplified Part (Formerly Shrinkwrap) feature.
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-E0D77EB7-7527-4DFC-A1A4-83FEFDF3B4DD
"Use Create Simplified Part to convert an assembly to a single part with no interior features. You can then further simplify the part file by removing details, filling voids and defining envelopes. "
You will want to use the 'fill internal voids' option.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
steveh3
Steve Hilvers
swalton
It looks like the model has some non-watertight surfaces.
Was this controller imported from a neutral file?
You may have to spend some time in the Construction or Repair environments to close all the gaps.
Steve Walton
Inventor 2025
Vault Professional 2025
andrewdroth
In that case I'd derive that assembly into a new single body part, but only bring in parts that are external. Then through a combination of deleting faces, and creating patches make a watertight envelope. It will take some time, but should be doable.
I can take a crack at it if you'd like.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
steveh3
Thanks everyone....was hoping for an easy button, but sounds like there isn't. I was able to get what I needed for the most part and was able to 3D print the main enclosure which is really what we were shooting for. Wasn't perfect but got us what we needed for now. Just needed to be able to hold in it in our hands.
Once again....THANKS!
Best,
Steve H.
Steve Hilvers
