How to Unfold This Part
akshay23241a0348
akshay23241a0348
I've acquired this part from a designer. This is not made using sheet metal operations, I think.
I want to unfold it to create a 2D sheet metal pattern.
How can I do it?
Thanks.
kacper.suchomski
Hi
This is not a modeled item using the sheet metal tools.
You can see that the product is not created by linear bending.
You can use the Unwrap tool.
Kacper Suchomski
akshay23241a0348
Okay thanks, I will try this tool.
akshay23241a0348
I tried using the unwrap command, but I'm getting a slight incongruity at the bottom right end.
Would the profile be appropriate anyways if I machine it?
And by the way, I had to select the faces manually after unchecking the "auto-chain faces" command as it was taking forever to process and my Inventor did not respond.
Thanks!
kacper.suchomski
The non-linear stamping process causes material deformations.
This means that if you try to read them backwards you cannot do so with 100% accuracy.
This is the nature of stamped parts.
You will need to make a series of prototypes and test the product through trial and error. Flat designs can be manually modified in AutoCAD.
Kacper Suchomski
akshay23241a0348
Okay, thanks!
