There is no UI workflows allow you to do that yet, however, this little VBA code will help you collect all the work points data in a part document and save the data to a text file under your C drive. Hope this is helpful.
Sub CollectWorkPoints()
Dim oComp As PartComponentDefinition
Set oComp = ThisApplication.ActiveDocument.ComponentDefinition
Dim oWorkPoint As WorkPoint
Dim oPoint As Point
Dim oFSO As Object
Set oFSO = CreateObject("Scripting.FileSystemObject")
Dim oFileout As Object
Set oFileout = oFSO.CreateTextFile("C:\WorkPoints.txt", True, True)
For Each oWorkPoint In oComp.WorkPoints
Set oPoint = oWorkPoint.Point
oFileout.Writeline oPoint.X & "," & oPoint.Y & "," & oPoint.Z
Next
oFileout.Close
End Sub
