Export to .obj files colors/materials not working in 2019?
seventhmoreno
Message 1 of 22
seventhmoreno
  • I currently upgraded to 2019 from 2017.
  • Working on a company project to move from 2d to 3D model space, i was using Inventor 2017 and exporting our assemblies to .obj files for an additional project. When i used 2019 and started exporting to .obj (same process)  the files did not have any materials when i opened it in Windows 3D Viewer using the same process.
  • Is this a feature that was taken out or does inventor have a setting i can toggle with?
Thank you,
-Al
Replies (21)
Message 2 of 22
MSD_takaseh
Hello seventhmoreno,
I think there is no difference between 2017 and 2019.
Please see the "newmtl" of .mtl file with opening the NotePAD. If color is not translated then the newmtl value is not RGB but characters.
Hitoshi Takase
Message 3 of 22
EvanGu
I can see the difference in the 2 .mtl files exported from 2017 and 2019. The newmtl value is not RGB, I will work with the project team for this issue.
Evan Gu
Inventor/Fusion QA Engineer
Message 4 of 22
seventhmoreno
is this a quick fix? I am asking because i would hate to delay my team so if this fix will take a couple weeks i will need to find another approach to export.
Message 5 of 22
EvanGu
2019.3.1 is the next update which will be released around Feb 7th. I have reported this problem to development team, and they are working on a fix.
Evan Gu
Message 6 of 22
EvanGu
Would you please let me know if you exported the file by another approach? Just checked with the project team, this issue is targeted to 2019.4 Update which will be released in early of April.
Evan Gu
Message 7 of 22
seventhmoreno
I was able to export as a .Step file but now it seems to export a transparent model is this the same issue? I am exporting my models into Fusion Team.
Message 8 of 22
seventhmoreno
Good morning,
Is there an expected date for this update/fix release?
Message 9 of 22
johnsonshiue
Hi! 2019.4 update has been released. Please check your account and see if you have access to the update. Install it and check if it has been fixed.
Many thanks!
Software Test Engineer
Message 10 of 22
jmayo-EE
Still an issue in 2020. No materials with obj export.
John Mayo
Message 11 of 22
johnsonshiue
Hi! For 2020, you may need to install 2020.1 to get the fix. Some of the fixes may appear in 2019.4 first followed by the next update to 2020, which is 2020.1. Please try 2020.1 and report back. It should have been fixed.
Many thanks!
Message 12 of 22
sverduyn
Still an issue in  2020.1.
Shaun
Message 13 of 22
Raider_71
Any further news on this issue? Would be nice to get this fixed...
Message 14 of 22
johnsonshiue
Hi Guys,
Based on our internal record, it should have been fixed as of 2020.1 and 2019.4.1 update. If you are still seeing the issue, we might have other issues. Please share an example exhibiting the behavior so that the project team can take a further look.
Many thanks!
Message 15 of 22
sverduyn
Please find attached the sample file requested.
Shaun
Message 16 of 22
WHolzwarth
IAM is not enough.
Included IPTs and sub-assemblies are needed, too.
Best way is uploading a zipped Pack&Go of the main assembly
Walter Holzwarth
Message 17 of 22
sverduyn
Apologies, bit hectic here at the moment. Please find a zip of the full assembly.
https://www.dropbox.com/s/jqfnvbfhm9yijlz/Fan.zip?dl=0
Message 18 of 22
jmayo-EE
Seems to work going into infraworks with the obj export. Colors are displayed correct for the one test I did.
John Mayo
Message 19 of 22
sverduyn
When I export the obj in 2019 I get the .obj, .mtl(with the correct mappings i.e. map_Kd 0036-18-1001/Metal_1.png)  files and a Folder with the png's.  When I export from 2020 I only get the .obj and .mtl files and the mtl file does not have the mappings.
Shaun
Message 20 of 22
sverduyn
The problem seems to be fixed now with the new Inventor 2020.2 update.
