When exporting files (ipt, iam) to, for example, step format, the first time (after startup) the location of the source file is used as the location for the step file, and the suggested file name is the same as the source file.
As of the second time I do the same action, the save location is changed to the root of the working folder and the suggested file name is not the same as the source name.
Please advise.
Solved by James_Willo. Go to Solution.
Solved by kacper.suchomski. Go to Solution.
Hi
Please update to 2025.1.1
Kacper Suchomski
Which version are you on? There was an issue with 2025 that's fixed in 2025.1.1
