I have an AutoCAD template where I've import in my Inventor DWG and put some model parameters in it. Whenever I export it as AutoCAD DWG suddenly the template will have these editing changes. With the original unexported AutoCAD template (right side in the snapshot) I can just type the datas directly in the box but on the exported template from inventor I still need to do couple of things to input/change datas. Is there any way to enable the quick edit option?
There is nothing wrong with using an Inventor .dwg file as your template. We did this at my last company and it worked fine with iproperties and in and out of Vault. But, like it has been suggested, I would create this template file with in Inventor and not import an Autocad .dwg file to start with.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
The fact that the template came from AutoCAD in the first place doesn't really have anything to do with the issue you are seeing. The cause is that when you export anything from Inventor that has prompted text, it comes in as a multiline attribute, which requires the extra editing button you mention.
This would happen on an Inventor export to AutoCAD even if the title block was originally created in Inventor. Happens with Inventor symbols as well (which was where I first learned about it). You have to fix this in AutoCAD - as far as I know there is no fix on the Inventor side (the problem doesn't actually exist until after the export to AutoCAD).
Look into how to convert multiline attributes to single-line attributes. It's been a while since I needed to do it, but I believe it required a LISP program.
