Export Stress Analysis Results
Good morning to all,
I would like to export the results of a stress analysis in a table format (.txt or other excel/matlab suitable format), in order to perform further analysis. Is it possible?
Thanks for the answers!
Roelof.Feijen
No, not with Inventor.
Post Processing in Inventor doesn't provide that kind of information.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
This is really bad, because those numbers somewhere exist (teorically I can place a probe in all the points of my model and read that results...) but I cannot read them.
Just to go deeper with my problem: I cannot use Von mises criteria because the material I am using is fragile and has a compressive strength 10 times its tensile strength. I would like to use e.g. Rankine or Mohr-Coulumb criteria... and I cannot use it without export results!
Roelof.Feijen
The only Autodesk software that can do this is Autodesk Simulation Mechanical.
Roelof Feijen
Thanks for your answers, sadly they are negative for me. I think it would be a simple and powerful improvement for Inventor to have this option and more in general much freedom to handle results.
blair
If you put ever option in Inventor, there wouldn't be much market for Simulation Mechanical. I'm pretty sure there are some headed discussions between product groups as to how much FEA to put into a design product before it no longer needs the FEA product.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Yes, I think we can close this discussion. However I think this is not a good explanation, it's like to say they are hidding some numbers to sell a software more, not exactly the best way to act. I mean, I have these numbers, the software has calculated them, I cannot export them... for commercial causes. Not good for me but understandable.
Thanks for your answers!
