Hello Everyone,
I am working with Inventor 2020 and we're trying to get a multi-sheet drawing to DWF only a specific amount of sheets. So say the drawing is 10 sheets but we only want page 3-5 to dwf print. Is there a way to do this?
Thanks!
Solved by johnsonshiue. Go to Solution.
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
See this post's iLogic code:
For iLogic and API post at Inventor Customization Forum for best results.
Please select the Accept Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
Hi! Yes, the option is available. You will need to click on Options button in Export to DWF (Save Copy As) dialog -> Custom -> Drawing -> select the sheets to be included.
Many thanks!
Hi! I guess so. Or you could check Inventor API and see if there is such control over which sheet to me included during Export.
Many thanks!
