export image
export image
artieavlonitis
export image
artieavlonitis
Is anyone else having issues exporting images?
Currently, when I use File->Export->Image, the output is not as I've come to expect, nor how it used to look prior to installing latest update, 2025.3.
See attached.
johnsonshiue
Hi! Please make sure all critical Windows updates are installed and the graphics driver is updated. Use Microsoft Disk Cleanup to remove cached files. Reboot the machine. Does it work better now?
Many thanks!
Software Test Engineer
artieavlonitis
still doesn't work. btw, this is happening on two different computers.
rui_wang
Hello @artieavlonitis
Thanks for your reporting. The issue has been tracked as INVGEN-84327.
This issue is related to transparency background options. If possible, please uncheck it during export image. Thanks.
richterBKSAC
Hi @rui_wang,
is there any workaround yet? Unfortunately unchecking the transparent background option is not an option for me.
Thank you
rui_wang
@richterBKSAC
Another way is using Render image in Inventor Studio.
Btw, the issue has been addressed and hopefully the fixing can be included in next update. Thanks.
