- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
i found a serious problem exporting from Inventor IDW to Autocad DWG:
The exported DWG file has the correct dimensions, but the geometry has been scaled! Even though i chose the correct option when exporting.
Apparently Autodesk is aware of this (https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Expor...).
The problem is related to the scale of the view in inventor which presents decimals (in my case 1: 8). So, I can't use custom scales otherwise the export generates incorrect files?
Exporting to DWG is required for sheet metal cutting, so you risk creating wrong pieces.
I use Inventor 2021 with last service pack and update.
I attach one video where see the problem.
Best regards.
Bruno Milano.
