Is there a way to export a 'Flat pattern' to dxf-file without getting line interuptions?
The programm we use for our laser/cutter needs contiguous lines.
I know that inventor sees the lines loose because they are flattened from a bent position and are therefore not a single line. But if there is a way to close this, it would be nice.
Thanks in advance!
Solved by TheCADWhisperer. Go to Solution.
Not that I am aware of. I know the flat pattern can be exported out as a dxf file in the form of a drawing, but the bend lines can be easily removed by turning off the visibility.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Its just the point that when we do that, Inventor exports a face with separate line parts.
The laser-program sees those lines and cut them all separately which results in a longer program.
By now we need to remove those separate lines and place a single line instead.
If there is a way in settings or so, to make an export with single lines instead separate lines per folded plate-part,
it would be perfect.
Can we also use or I will use below option..
Go to Flat Pattern then select actual models face as shown in below
right click and export face as .dxf and save the file..
I always prefer this option for creating laser profile.
Thank you and best regards,
Dnyaneshwar Maid
As @TheCADWhisperer has said, select Merge Profiles into Polyline when doing Flat Pattern Export and you can choose which lines are visible or not, or open the export in Autocad and merge the lines into polyline and perform your other edits there as well. If somehow Inventor is exporting lines with missing geometry leaving obvious gaps in the profile, then there may be some other errors that aren't apparent yet.
EDIT: Is it possible for you to upload your part as an .ipt instead of STEP?
Because i cant remove the other one... Something thats super dumb over here 😉 This was my main topic, had that tap open. So by accident posted it in that topic..
I am writing on this post again for just my interest..
I tried with option "Flat pattern save as .dxf" and setting as per option which shown in TheCADWhisperer post but I do not think it is giving best result compare to "export face" as option. I am attaching here with files which I tried with both option "Flat pattern save as .dxf" and "export face" with file naming self explaining.
With export face showing two best option that it gives radius at bend line which is desirable from deign point of view OR not! and second option as we can select face which we want in this case 940.00 mm lengtg face or 940.50 mm It gives more benefit when part having counter hole so in that case we can select face with smaller hole.
I hope you all understand what I mean but if any doubt please let me know.
Please confirm which option is better from above for future reference
Best reagrds,
Dnyaneshwar Maid
