Inventor Forum
Export DXF options
3 REPLIES 3
DaveWhelan
1124 Views, 3 Replies
Export DXF options
I do not have a save as or export to dxf in Inventor 2018.
Ideas?
Tags (2)
3 REPLIES 3
johnsonshiue
in reply to: DaveWhelan
Hi! Inventor DXF export is limited to 2D geometry. You can export a 2D sketch, a planar face, a flat pattern, and idw/dwg file. See the following technical document.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
What environment are you trying to export DXF?
Many thanks!
Software Test Engineer
DaveWhelan
in reply to: johnsonshiue
Thank you for responding.  Your comments made me think about what I was doing.  I designed a robotic cell and placed it in a .idw file but still could not save it as a dxf until I right clicked on the .iam file and changed the Section Participation from Section to None.  I could then save as a dxf file.
I did not have to do that in previous versions.
Thanks for your help.
Dave
johnsonshiue
Hi! Is the drawing view a raster view? If you right-click on the view icon in the browser or graphics window, do you see an option "Make View Precise"? If yes, the view is a raster view, not a precise view. I don't think Inventor supports exporting raster views to DWG/DXF.
Many thanks!
