Inventor Forum
Export assembly as individual step files
22 REPLIES 22
Message 1 of 23
9817 Views, 22 Replies
Hi all,
I am able to export the assembly as one step file with the full model tree but I am trying to export an assembly into individual step files of every component in that assembly, is there any way to do this easily?
Cheers,
Iain
Hi all,
Cheers,
Iain
22 REPLIES 22
Message 2 of 23
Roelof.Feijen
Roelof.Feijen
Hi Iain,
I don't think you can do this in Inventor without customization.
NXTdim Batch Publish van do it. You can download a trial form the Inventor Exchange
https://apps.autodesk.com/en/Publisher/PublisherHomepage?ID=HUSPL4JKGND7
Otherwise you need to write your own VBA or iLogic rule to do this.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Hi Iain,
Roelof Feijen
Message 3 of 23
in reply to: Roelof.Feijen
Hi Roelof,
Thank you for your reply, is there anywhere I can look for guidance on creating an ilogic rule to do this?
Iain
Hi Roelof,
Iain
Message 4 of 23
mdavis22569
mdavis22569
Look at your Task Scheduler ...
It has an Export option. You can do all of the files in an IPJ..
Might need to tweak it a bit
Mike Davis
Mike Davis
Message 5 of 23
in reply to: mdavis22569
Hi Michael,
I used Task Scheduler in the end but it wasn't ideal because all the files were in several different folders and not necessarily all the files in that folder either.
What I really want is for all the components visible in the model view of an assembly to be exported, I am currently trying to write an illogic script to do just that.
Cheers,
Iain
Hi Michael,
Cheers,
Iain
Message 6 of 23
Justin.Williams
Justin.Williams
I have been using the iLogic code provided in the link below to export PDF files of drawings for each component in an assembly.
I bet this code can be modified to make it export .stp instead of a PDF of the drawing. I wish I knew how, because this is something I also want to be able to do. I currently use task scheduler and select each component manually and change the export option to .stp one at a time.
Does anyone know how to modify it to make it export .stp?
http://inventortrenches.blogspot.com/2012/11/ilogic-batch-output-pdfs-from-assembly.html
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
End If
'get user input
RUsure = MessageBox.Show ( _
"This will create a PDF file for all of the asembly components that have drawings files." _
& vblf & "This rule expects that the drawing file shares the same name and location as the component." _
& vblf & " " _
& vblf & "Are you sure you want to create PDF Drawings for all of the assembly components?" _
& vblf & "This could take a while.", "iLogic  - Batch Output PDFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
End If
'- - - - - - - - - - - - -PDF setup - - - - - - - - - - - -
oPath = ThisDoc.Path
PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
'oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
'get PDF target folder path
oFolder = oPath & "\" & oAsmName & " PDF Files"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has a drawing of the same path and name
For Each oRefDoc In oRefDocs
idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw"
'check to see that the model has a drawing of the same path and name
If(System.IO.File.Exists(idwPathName)) Then
                        Dim oDrawDoc As DrawingDocument
                oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
            oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -3)
            On error Resume Next ' if PDF exists and is open or read only, resume next
                 'Set the PDF target file name
                oDataMedium.FileName = oFolder & "\" & oFileName & "pdf"
                'Write out the PDF
                Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
            'close the file
                oDrawDoc.Close
Else
'If the model has no drawing of the same path and name - do nothing
End If
Next
'- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - -
oAsmDrawing = ThisDoc.ChangeExtension(".idw")
oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True)
oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -3)
'write out the PDF for the Top Level Assembly Drawing file
oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & "pdf"
'Write out the PDF
Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium)
'Close the top level drawing
oAsmDrawingDoc.Close
MessageBox.Show("New Files Created in: " & vblf & oFolder, "iLogic")
'open the folder where the new ffiles are saved
Shell("explorer.exe " & oFolder,vbNormalFocus)
Owner / Designer
Modern 3Design
Exit Sub
End If
'get user input
& vblf & " " _
Return
Else
End If
End If
End If
                'Write out the PDF
            'close the file
                oDrawDoc.Close
Else
End If
Next
'Write out the PDF
Owner / Designer
Modern 3Design
Message 7 of 23
salariua
in reply to: Justin.Williams
salariua
drawings as stp?
you mean assembly structure (parts and subcomponents to stp)?
it's not that difficult, will give it a stab.....
Oops....I've done it already, and forgot about it.
Check it here: http://blog.ads-sol.com/2016/01/batch-assembly-export.html
Good Luck.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
drawings as stp?
Good Luck.
Adrian S.
blog.ads-sol.com
Message 8 of 23
Justin.Williams
in reply to: salariua
Justin.Williams
Thanks for sharing! That was helpful, but I need step files for ONLY files which have a drawing. I modified your code a bit so that it first checks to see if a file has a drawing, and if a drawing exists, it will export the step file.
Hopefully someone else finds it helpful! This will be a huge time saver for me
Exit Sub
End If
'get user input
"This will create a STP file for all of the asembly components that have drawings files." _
& vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
& vbLf & " " _
& vbLf & "Are you sure you want to create PDF Drawings for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic  - Batch Output PDFs ",MessageBoxButtons.YesNo)
Return
Else
End If
'- - - - - - - - - - - - -STEP setup - - - - - - - - - - - -
'get STEP target folder path
oFolder = oPath & "\" & oAsmName & " STEP Files"
'Check for the step folder and create it if it does not exist
End If
            On Error Resume Next ' if PDF exists and is open or read only, resume next
                'Write out the PDF
            'close the file
                oDrawDoc.Close
Else
End If
Next
'Write out the PDF
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
Owner / Designer
Modern 3Design
Exit Sub
End If
'get user input
& vbLf & " " _
Return
Else
End If
End If
                'Write out the PDF
            'close the file
                oDrawDoc.Close
Else
End If
Next
'Write out the PDF
Owner / Designer
Modern 3Design
Message 9 of 23
salariua
salariua
Uhhh..... goodies
I am soooo gonna be stealing your code now!
Brill find, keep up the good work @Justin.Williams
Adrian S.
blog.ads-sol.com
Uhhh..... goodies
Adrian S.
blog.ads-sol.com
Message 10 of 23
Thanks for all the responses! That code works miracles! I also found this thread from Feb '16 that looks to see if the file is part of the Normal BOM structure before export.
http://forums.autodesk.com/t5/inventor-forum/ilogic-to-export-step-from-marked-as-normal-in-bom/td-p...
Cheers,
Iain
Cheers,
Iain
Message 11 of 23
mazur.peter
mazur.peter
This post is a Great! 🙂
Let me one question. If I want to add more data to a step file name (custom iProperties), how can I make it?
So I create a custom iProperty (i.e.: "comp_drawno") in a custom property tab. How can I add to the code to create the step file name with comp_drawno?
Many thanks
Many thanks
Message 12 of 23
Could you please explain of how to fix the compile errors that occur .
I clicked on Add Rule, gave it a name(Rule) and pasted the code.
Message 13 of 23
Hi guys,
I appreciate  your effort in providing a solution. Unfortunately, my problem goes a little further. Maybe one of you has an idea how to fix it.
I also need a way to export assemblies as STEP files with individual files for each of the assembly's components.
However, in the end I want the STEP-file of the assembly to only contain references to the components' files but not the entire assembly's geometry.
In creo parametric there is such an option.
The reason we need this is that our own software is capable of importing step data. If we or our customers were able to sort out certain components such as standard parts in the windows explorer, the imported models would be much leaner, increasing our software's performance.
If you could think of any way to establish such a procedure, I would really appreciate any hint.
Thank you! Cheers, Malte Vollmer
Hi guys,
Tags (3)
Message 14 of 23
johnsonshiue
johnsonshiue
Hi! I think I know what you are talking about. But, I don't think Inventor supports such STEP Export workflow. I need to work with the project team to understand the request better and how we can accommodate it.
Many thanks!
Software Test Engineer
Many thanks!
Message 15 of 23
johnsonshiue
johnsonshiue
Hi! I got confirmation from the project team that the distributed STEP files are not yet supported. Please submit it as an idea to Inventor Ideas forum (https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232).
Many thanks!
Many thanks!
Message 16 of 23
Hi, I am trying to use this iLogic rule to export PDF's and STEP files of my assembly. There are a plethora of errors with Inventor 2018. Is there an updated rule I can use? I don't understand much about iLogic rules other than how to add them.
Message 17 of 23
dliteful
dliteful
This is what I was able to come up with for PDF & STEP files.  Works good, but I can imagine it would take a while with larger assemblies.  This was created in Inventor 2017, so I hope there are not 2018 bugs for you.
Sub Main()
        Exit Sub
    End If
    'get user input
    If MessageBox.Show ( _
        "This will create a PDF & STEP file for all of the assembly components that have drawings files." _
        & vbLf & " " _
        & vbLf & "Are you sure you want to create these files for all of the assembly components?" _
        & vbLf & "This could take a while.", "iLogic  - Batch Output STPs ",MessageBoxButtons.YesNo) = vbNo Then
        Exit Sub
    End If
    Dim PDFAddIn As TranslatorAddIn
    Dim oContext As TranslationContext
    Dim oOptions As NameValueMap
    Dim oDataMedium As DataMedium
    Call ConfigurePDFAddinSettings(PDFAddIn, oContext, oOptions, oDataMedium)
    oFolder = oPath & "\_" & oAsmName & " PDF & STEP Files"
    End If
    '- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -'
    For Each oRefDoc In oAsmDoc.AllReferencedDocuments
        idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentNaMe) - 3) & "idw"
            Dim oSTEPDoc As Document
            oSTEPDoc = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
            oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -4)
            oRevNum = oDrawDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
'            On Error Resume Next
'            'Set the PDF target file name
                If oRevNum = Nothing Then
                oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
                oSTEPDoc.SaveAs(oFolder & "\" & oFileName & (".stp") , True)
                Else
                    oDataMedium.FileName = oFolder & "\" & oFileName &  " Rev." & oRevNum & ".pdf"
                End If
                oDrawDoc.Close
                oRefDoc.Close
            On Error Goto 0
        End If
    Next
    Dim oAsmDrawingDoc As DrawingDocument
    oAsmDrawingDoc = ThisApplication.Documents.Open(ThisDoc.ChangeExtension(".idw"), True)
    oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -4)
    oAsmDrawingRev = oAsmDrawingDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
'    On Error Resume Next'    'Set the PDF target file name
                If oAsmDrawingRev = Nothing Then
                    oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & ".pdf"
                Else
                    oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & " Rev." & oRevNum & ".pdf"
                End If
End Sub
Sub ConfigurePDFAddinSettings(ByRef PDFAddIn As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
    oOptions.Value("All_Color_AS_Black") = 1
    oOptions.Value("Remove_Line_Weights") = 0
    oOptions.Value("Custom_Begin_Sheet") = 1
    oOptions.Value("Custom_End_Sheet") = 1
End Sub
Sub Main()
        Exit Sub
    End If
    'get user input
        & vbLf & " " _
        Exit Sub
    End If
    End If
                Else
                End If
                oDrawDoc.Close
                oRefDoc.Close
            On Error Goto 0
        End If
    Next
                Else
                End If
End Sub
End Sub
Message 18 of 23
hamza_khan1
in reply to: dliteful
hamza_khan1
Hi, i am trying to export Step files of the parts only from the main assembly and want the description and filename to be a part of Step file name.
Is there any way around that? i tried to run the provided ilogic in sections but no result.
Message 19 of 23
SBix26
in reply to: hamza_khan1
SBix26
I suspect that the Inventor Task Scheduler would be helpful here.  You don't say which version of Inventor you're using, but here is the 2020 Help section for Task Scheduler.
Task Scheduler allows you to select files to be exported by project, by folder, or by individual selection.  Hope that does what you need.
Sam B
Inventor Pro 2021.2 | Windows 10 Home 2004
LinkedIn
Sam B
LinkedIn
Message 20 of 23
dliteful
dliteful
Hi hamza.khan -
I added a line to grab description from components and changed the Save As path (shown in bold green below).  This is more simplified than the PDF & STEP one that I posted earlier, but if you still want that functionality, just add to it.  Hope that's what you were looking for.
Sub Main()
		Exit Sub
	End If
	'get user input
'	If MessageBox.Show ( _
'		"This will create a STP file for all of the asembly components that have drawings files." _
'		& vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
'		& vbLf & " " _
'		& vbLf & "Are you sure you want to create STP Drawings for all of the assembly components?" _
'		& vbLf & "This could take a while.", "iLogic  - Batch Output STPs ",MessageBoxButtons.YesNo) = vbNo Then
'		Exit Sub
'	End If
	Dim STEPTranslator As TranslatorAddIn
	Call ConfigureSTEPTranslatorSettings(STEPTranslator, oContext, oOptions, oDataMedium)
	oFolder = oPath & "\_" & oAsmName & " STEP Files"
	End If
			oDesc = oSTEPDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
	'Save as STEP
	oSTEPDoc.SaveAs(oFolder & "\" & oFileName & " " & oDesc & (".stp") , True)
				Call STEPTranslator.SaveCopyAs(oSTEPDoc, oContext, oOptions, oDataMedium)
				oRefDoc.Close
			On Error GoTo 0
		End If
	Next
End Sub
Sub ConfigureSTEPTranslatorSettings(ByRef STEPTranslator As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
	oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
	If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
    ' Set application protocol.
    ' 2 = AP 203 - Configuration Controlled Design
    ' 3 = AP 214 - Automotive Design
    oOptions.Value("ApplicationProtocolType") = 3
    ' Other options...
    'oOptions.Value("Author") = ""
    'oOptions.Value("Authorization") = ""
    'oOptions.Value("Description") = ""
    'oOptions.Value("Organization") = ""
'    Dim oData As DataMedium
    oDataMedium.FileName = ThisDoc.PathAndFileName(False) & ".stp"
oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oDataMedium)
End If
End Sub
Hi hamza.khan -
Sub Main()
		Exit Sub
	End If
	'get user input
'		& vbLf & " " _
'		Exit Sub
'	End If
	End If
	'Save as STEP
				oRefDoc.Close
			On Error GoTo 0
		End If
	Next
End Sub
    ' Other options...
End If
End Sub
