Inventor Forum
Export 2D sketch points to DXF
6 REPLIES 6
Walt_Jaquith
1010 Views, 6 Replies
Walt_Jaquith
I have a client that's attempting to export a sketch from Inventor which contains 2D sketch points.  The resulting DXF file contains all the geometry except the points.  I've tried several methods and can't get the points to come through.
This is important for those working with CNC burntables.  The table can usually centermark the work on a point in the file.  Any help here?
6 REPLIES 6
mcgyvr
in reply to: Walt_Jaquith
mcgyvr
You need to right click on the flat pattern node and select "Save Copy As" in order to get the "IV_ARC_CENTERS" layer which will add center points to any circles/arcs in the sheet metal part.
Walt_Jaquith
in reply to: mcgyvr
Walt_Jaquith
There are no circles or arcs; just sketch points in a sketch.  Inventor will export all other sketch geometry, but evidently not the points.  When I convert the part to sheet metal, create a flat pattern and export the DXF from that, the points still don't come through.
The client doesn't want holes in the part.  Those get drilled later.
johnsonshiue
johnsonshiue
Hi! I believe it will depend on what kind of points. For regular sketch points (like a dot), they are not exported. But, center points (like a cross) will be exported.
Try a few things.
1) Open the sheet metal part -> go to Flat Pattern -> right-click on the FP node in the browser -> Edit Flat Pattern Definition -> Punch representation -> choose one of the Center Mark options.
Or 2) Edit the sketch -> change the sketch points to center points.
If it still does not work, please share an example here.
Many thanks!
Software Test Engineer
Try a few things.
Many thanks!
Walt_Jaquith
in reply to: johnsonshiue
Walt_Jaquith
I'll give that a try, Johnson, but as I said, this is not a sheet metal part.  The client does not want to convert it to sheet metal, or put punches on it.  It's a simple sketch with regular Inventor sketch geometry.  If you look at the screencap, you will see a sketch with  a rectangle, center points and regular points.  If you right-click on that sketch and select "Export Sketch As...", the rectangle will be exported to the generated dxf file, but the points of either style will not.  Why not?
It doesn't seem reasonable to me to have to convert to sheet metal and add unwanted punch features just to get this functionality.
johnsonshiue
johnsonshiue
Hi! I cannot explain it. I think it is like an incomplete implementation. It would be great if there is an option allowing the points to be included.
Many thanks!
Many thanks!
tony_berset
tony_berset
Here is an existing idea for this lack, do not hesitate to vote : https://forums.autodesk.com/t5/inventor-ideas/points-and-centerpoints-should-export-to-dxf-out-of-a-...
