When i try for instance to calculate a area of a piston using fx i type in;
When i press enter fx autmaticly corrects the equasion to;
Wich is obviusly not what i need. I try to correct the formula as follows;
Seems correct, but when i press enter the following happens;
Am i doing sometihing wrong? Or is this a bug?
Solved by johnsonshiue. Go to Solution.
Hmm. Perhaps a bug.
Try that: ( Cilinder_bore ) ^ 2 oE * PI / 4 oE
Walter
Walter Holzwarth
Mmm,
It seems to do the trick
But, as a test, when i ad a piece before the equasion;
So it looks like the above and press enter, inventor changes it again.
(the answer is correct, but he formula is adjusted!?)
Hi Guys,
The behavior does not look logical. IT looks like a defect to me. I will report it as a defect and see what we can do.
Many thanks!
