Inventor Forum
Explode Blocke in inventor
4 REPLIES 4
1249 Views, 4 Replies
Pls let me know how would i explode the block in inventor.
Modification of a block is no problem, Bt i want to explode a block, In stead os same 4 block i have to change 1 only by exploding..So Is there any command to explode a 1 block out of 4?
4 REPLIES 4
cbenner
Can you explain what you mean by a block?  Are you working in a part environment, assembly or drawing?  Maybe a picture of what you are trying to change?  A "block" is more of an Autocad term for a group of 2D entities tied together to make a symbol or something similar.
JDMather
Simply right click on the block you want to explode and select Explode.
in reply to: JDMather
Dear Mr. JD ...
Thanks you sir.. ..
Technology Administrators
