- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've created a rectangular prism that is twisted by lofting with rails.
My intentions are to make a perfect ring using the twisted rod.
The rings inner dimension must be 16mm with its outer dimension being 20mm.
This means that diameter from the centre of each side of the ring must be 18mm.
18*Pi = 56.548667764616278292327580899031
This is the length of my rod, or, the center circumference of the ring.
I attempted to bend the part 360 degrees with a radius of 9 or (18/2).
It shows me a perfect preview of what i want, but when i press okay it says it failed.
If i give it a radius of 9.001 or anything higher, it works.
I understand the complexity of the design, but why can't I execute it at a value of 9? did I do something wrong? Help Please!
