Error when mirroring surface
jeffreyVR4JW
jeffreyVR4JW
Hi!!
I have been learning how to surface model through youtube for the past few weeks. I have started on my first project, which is making my head. The only problem is that, when I try to mirror my stitched surface, it gives me an error. I know it has something to do with sketch 2 of my project, but i just don't know why. (Know this because this where the i with blue circle icons show up next to my sweeps. lofts, etc. Any help/ guidance will be greatly appreciated
Thanks!!
Fouad-l
Hi @jeffreyVR4JW .
The sketch 9 is the problem. It contains a lot of indefined geometry (Magenta). If you don't want to delete them, select them all and delete theire constraints as indicated in the image below. I attached the model with mirror created without any problem.
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
jeffreyVR4JW
Thank you so much!!
