Error 'The database in [filepath] could not be opened' for DWG files
Freek046
Freek046
I just upgraded from a Win 7/Inventor 2012 to a Win10/Inventor 2017 system. I can open all old 2012 files, but when I save DWG files to 2017, I cannot open them anymore and get the message above. I can also not start a new drawing, starting with my 2012 to 2017 saved template (DWG) file. So, the problem is with the DWG's.
Can anybody help me with this?
Cadmanto
See the attached link from the help file.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johnsonshiue
Hi! I believe this is related to Inventor DWG version. Go to Tools -> Application Options -> Drawing -> Inventor DWG File Version. Set it to AutoCAD 2010. Then, the dwg file save in Inventor will be compatible to AutoCAD 2010. And, AutoCAD 2012 should be able to open it.
If you are export Inventor idw/dwg to AutoCAD dwg, make sure you change the export version to AutoCAD 2010 also (last used). Or, you can save the setting as a .ini file so you can use it later.
Many thanks!
Software Test Engineer
Freek046
I did some more tests yesterday and found out that also new Inventor 2017 DWG files cannot be re-opened. So, I think it has nothing to do with the previous version I worked with.
If I try to open the iProperties of a newly created (and saved) DWG file, I get an error (see 'Error iProperties 2017 DWG'). When I continue anyway, I can see no version information (see 'iProperties 2017 DWG') which cannot be ok. As a reference when I create and save a PRT file I can re-open the file and also the iProperties give version information (see 'iProperties 2017 IPT'). What I find a bit strange is that this says '2017.3 (Build 213256000, 256)' while my installed version is 'Build: 256, Release: 2017.4.8' (see 'About Inventor 2017'). Don't know if this is of any importance.
After this I did a repair and reinstall of DWG TrueView 2017 and Inventor Professional 2017 without any result.
Any suggestions are appreciated.
Error iProperties 2017 DWG.jpgiProperties 2017 DWG.jpgiProperties 2017 IPT.jpgAbout Inventor 2017.jpg
Freek046
I tried that ... didn't help. Please see my reply (4)
Freek046
I tried that too ... didn't help. Please see my reply (4)
Freek046
SOLVED!
It turned out to be a language setting of Windows 10. I found out I also had problems with opening Autocad 2017 and with solving that, the Inventor DWG problem was also solved.
I changed the default app language from English (Netherlands) to English (United States).
