Error open Autodesk inventor 2017
Message 1 of 8
look error????
Replies (7)
Message 2 of 8
Cadmanto
Welcome to the forum,
Would you give us some more info please?  Looks like it is having issues with finding certain files which means either the designated file is missing or moved.
Is this a new install and this is happening?  Did you just upgrade an old version?  Did you close inventor come back and reload it and this happened?
Basically we need to know what circumstances lead up to this point.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 8
Mark.Lancaster
@Anonymous
Welcome to the community..
Just means you have corrupt XML file.  Attach is a good one..  Replace when Inventor is not running.  Good luck and report back on your progress.
Mark Lancaster
Message 4 of 8
Hello e Thanks for the answer
I simply closed the inventor and suddenly the windows gave Blue screen (fatal errors) and reniciou the PC and it was thus
Message 5 of 8
Message 6 of 8
Cadmanto
I know you got the blue screen of death, but have you done a hard reboot after it came up from the blue screen?
If you have, and it still is giving you these errors, I suggest going under the control panel, find the Inventor under the programs list and doing a repair on it and see if that fixes your issue.
Best Regards,
Scott McFadden
Message 7 of 8
NOP
NOT OK....
Message 8 of 8
Mark.Lancaster
@Anonymous
Did you ever replace your corrupted file with the one I sent you in my posting?
Mark Lancaster
