Inventor Forum
Error: Multiply 2 dimensions in sketch:
2 REPLIES 2
624 Views, 2 Replies
It seems I can get an error if while in a sketch I attempt to dimension a line using this formula: d0 * d1 "The expression's units do not match the expected units. Expected [m] but found [m^2] Any idea how to work around this?
2 REPLIES 2
JDMather
This works just like in hand calculations.
You will need to add a modifier to get the correct units.
This is typically done by dividing by 1(unit).
Attach your file here if you can't figure it out.
in reply to: JDMather
Thanks that solved it.
Technology Administrators
