Error message while saving
CWC_Drawing_Office
CWC_Drawing_Office
Hi all,
I am trying to save a part and it is giving me an error message & I cannot understand why.
WHolzwarth
I didn't count the characters, but perhaps the naming of file and folders exceeds the allowed limits.
Walter Holzwarth
-niels-
My guess would be that the path is too long...
Does it save when you try saving it to your desktop or C: drive directly?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
CWC_Drawing_Office
Hi all,
I figured the problem out, I used the multi-solid workflow and then deleted a feature which deleted the 2nd body, this did not delete the actual solid body in it's folder. So when saving it gave that error.
I started over with a new ipt and it's fine.
-niels-
Glad you solved it!
If you're able to consistently recreate the error, i bet the people at Autodesk would love to know the steps involved. (even if it's part specific)
Niels van der Veer
The Netherlands
Gabriel_Watson
This had possibly something to do with the superscript power of 3 in the path (20m^3) of the file. See related solution about special characters specified in your full path here:
https://forums.autodesk.com/t5/inventor-forum/error-database-could-not-be-saved-while-placing-the-co...
CWC_Drawing_Office
I will try to recreate the error at some point and if it does repeat I will be more than happy to share the process followed.
