Error message while saving.
WEISMAT
WEISMAT
There was an error message about "Presentation" and how to fix it. But I cannot uncheck the hook left of "Master".
See picture and attached model. I am sure the solution is simple. By the way, I don't know what this think generally means. Is this the similar to "Journal" in NX?
JDMather
Can you post the error message?
There is a "sick" point in Sketch3 (indicated in browser and pink in the sketch).
Master View Rep is always locked.
WEISMAT
Thank you!
johnsonshiue
Hi! I believe you were trying to create a graphical section view when the part has Master Design View active. It is an annoying warning. It just means that the section view cannot be saved in Master Design View.
Many thanks!
Software Test Engineer
