- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am very new to Inventor ( not new to solid modeling) and have started working with it to transition from my current modeling software.
I started a model last week saved it to a directory I created and now I am getting the attached error message.
What am I doing wrong?
Also once I get it open I need some help. The profile that I have created will not extrude. The holes in the profile will extrude as solids, not what I want, but the outer block that the holes are supposed to be in will not. Is there someway in Inventor check the geometry and make sure that all of the lines on the perimeter are connected and will form a surface that can be extruded? Third question: How can I import a series of points in space that will be connected with a spline. I have figured out how to import the points, but they are just points.
teb
