Inventor Forum
Error locking the file ... Error code 64?
4 REPLIES 4
GustavStigsohn
712 Views, 4 Replies
I get this error alot when I try to save. Often it helps just to restart Inventor but I then loose all work.
What is the problem? How can I resolve it?
I can't see any pattern, it just happens randomly.
Any ideas are very much appretiated!
I'm running Inventor 2013 on Vista 64-bit
4 REPLIES 4
ampster40
in reply to: GustavStigsohn
sounds like you are saving/working off a network drive and your system is loosing it's connection every now and then.
GustavStigsohn
in reply to: ampster40
Yes, I forgot to mention! All files is on our server. I never had any problems with accesing the server or opening other files when this happens though?
Also, a restart of Inventor fixes the problem. No ideas?
ampster40
you may have to work with your local IT or IS to resolve why your pc or Inventor looses the network connection.
