- Mute
- Permalink
- Report
I have a sheet metal panel, on each side (left, right, top, bottom) I made a hole and then a pattern of that hole. This works perfectly. I placed this part in an assembly and authored it for icopy. Still works perfectly fine, I have used this to make lots of these panels.
Now I'd like to add screws to all the holes, so my idea was to add one to the first hole in every side and then create a component pattern that follows the feature pattern in the part. And this also works perfectly.
Except when I want to suppress the holes in one or more sides. With ilogic, I suppressed the holes in the part, I suppressed the component pattern. But I still get an error because the initial constraint of the first screw was made to the geometry that has now been suppressed, so of course that makes sense. But how can I work around this?
Am I missing something really obvious? Would my only option be to create work geometry in the part to constrain the screw to?
