Error during Extrude Join Distance from Face: "The feature as specified did not change the number of faces"
Is anyone else experiencing this problem with some Join Extrudes?
Extrude > Join Distance from Face produces an alert when the Start plane/face is on or within body being joined, the extrusion intersects and terminates within the body being joined.
No error when the extrusion does not intersect body being joined.
No error when the extrusion starts or terminates outside the body being joined.
No error when the sketch profiles being extruded are larger than the body being joined.
No errors with join between.
Example .ipt attached shows a number of test bodies. Green bodies are okay. Red bodies have error.
The error can be accepted and the extrude will be visible but use of the affected .ipt's will trigger further error dialogs downstream.
James
