Error after use chain dimension of thread position
premysl.misun
premysl.misun
in Inventor 2020 is problem with chain dimension of thread holes. If I select this threads by rectangle, dimension is not correct. I have to select only holes of threads one by one. Select thread "circle" also did not work. In previsous versions this was ok. See in picture.
johnsonshiue
Hi! Many thanks for reporting the issue! This is indeed a bug. The behavior starts from 2020 and it worked on 2019 and before. I will work with the project team to understand the issue better. In the meantime, please select the hole edges to place Ordinate Dims instead.
Thanks again!
Software Test Engineer
johnsonshiue
Hi! Just to provide an update, the issue has been reported as INVGEN-29596. The same issue exists in baseline dimension. Hopefully, it will be fixed soon.
Many thanks!
