Equation in parameters resets always
berry.lejeune
berry.lejeune
Hello all,
In trying to make my job a bit quicker I've made some assemblies with an underlaying sketch which includes all the dimensions needed to make my assemblies. Now I've come to a strange thing which I'm unable to figure out why it always fails. Here's the issue: In the sketch there are a bunch of parameters. These parameters I copy to my individual parts. So far all ok. In the part I rename these parameters so they show up in my parts list. Thickness (dikte) is one of these parameters. In making the part I link the extrude to the thickness (dikte) as you can see in the screenshot below.
But when I update my main sketch, the extrude changes to a fixed value and the link to the thickness (dikte) is gone (screenshot below)
Other parts who use this thickness(dikte) have no issue with it. The extrude stays linked to the thickness (dikte) So I have no clue at all why some parts are having this issue and others don't.
BM_Ashraf
I think the Problem is the Parameter d3 in the screenshoot 2 is not correctely defined.
The dikte is right (50.000 mm), you have to link it to the Model Parameter d3
- Just delete the 40.000 mm and write dikte and it will work !
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
berry.lejeune
That's what I did. But when I change the value to "dikte" and later on I do an update of the part (new thickness) the value of "dikte" changes again to a numerical like in my second screenshot.
But I just found out what the problem was. For each new level of parts, I used the marked parts as a constraint to get them on the correct height. When I delete this constraint and I constrain all the parts of a new level to a plane, then the issue what I have is gone.
Now I just have to figure out how to link the heights of all the planes I use to my sketch so all keeps updating as it should
BM_Ashraf
Glad that you solved the first problem !
You can make the Planes with the same Parameters as the main sketch.
Blue Mech
berry.lejeune
I managed to link the height of all the planes to the corresponding dimensions as you can see in the screenshot
When I change my base part dimensions, all of the parts update nicely and the height of the planes are also changed as they should do 🙂
BM_Ashraf
Great, you already solved the Problem by your own!
Great job !💪
Blue Mech
johnsonshiue
Hi Folks,
Another way to associate the parameters in different components within an assembly is to use iLogic. Create an iLogic rule at the top-level assembly. You will be able to access the parameters in different component documents. And, you can write rules to drive them.
The nice thing about this approach is that such cross-document relationship is managed by an iLogic rule, which is relevant to the particular context. The individual components remain self-contained.
The traditional parameter linking or derive workflow essentially establish cross-document relationship regardless where the part is used. Such relationship may only make sense in one context but not others.
Many thanks!
Many thanks!
Software Test Engineer
