Custom column not usable with Frame Generator or Bolted connection
Rob67ert
Rob67ert
You can add columns to your Content Center parts, let say Preferred. You can use that column when you place a bolt. How can I use this column with a Bolted Connection, or with Frame Design?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
CGBenner
@Rob67ert
I don't think there is any way to use this column as a selectable option during placement using those tools, the selection menus use only predefined parameters.  The best you could hope for, I believe, is to have it populate a custom iProperty on the generated components for use with your BOM as an example.
Chris Benner
Frederick_Law
Add "Preferred" in Description:
Not sure if you can put _ infront and get them to sort to the top.
