Inventor Forum
EOP
17 REPLIES 17
Message 1 of 18
1975 Views, 17 Replies
EOP
When I tried to move EOP to extreme down  following error message is coming. How to fix it?
17 REPLIES 17
Message 2 of 18
Mark.Lancaster
@Anonymous
And what does the message state?  Its right there (the reason why its failing)  Smiley Wink
Mark Lancaster
Message 3 of 18
JDMather
Sketch5 has a repeated dimension and is missing a Tangent constraint.
Sketch8 has sick geometry (pink circle) that I assume was projected from a feature that was removed.
Did you remove a Ø.605 cylindrical feature or circle that existed earlier?
I notice that there is no Sketch 3, or 6.  Did you use these sketches as parents and then delete them?
I notice that there are about 20 missing parameters.
Did you have a bit of trouble getting this far?
(There is nothing inherently wrong with having missing parameters - but from experience I associate this with a lot of fumbling around in creation of the geometry.  You part is easily fixed by deleting the sick geometry or by deleting the projected constraint and re-dimensioning/constraining the circle.)
Message 4 of 18
CCarreiras
So, you learned that you can not playing with the eop as you like, but just when you strictly need.
The cause is.... shhhht happens, inventor (or other any cad programs) are not perfect, so, don't mess to much with it.
The other reason is... you're not perfect too, so, this is only one more step in your cad knowledge.
Solution: Try to repair all the mess caused by the "playing with the eop" and don't do it again, unless you stricly need to do so.
If you can't repair, do the part from the beggining.
CCarreiras
Message 5 of 18
in reply to: CCarreiras
For me it seems like cryptic message. Are you able to understand it?
Message 6 of 18
in reply to: JDMather
Answer to questions will follow soon.
Message 7 of 18
Curtis_Waguespack
Hi fiatnm,
To fix the sketch you will want to right-click on the pink / magenta circle and choose Break Link, then you can dimension and constrain it in place, and update your feature.
Also, if it were me, I'd want Extrusion5 under Extrusion1. We typically want sketched base features first and then placed features (fillets, chamfers, patterns, shells, etc. ) last. That way you don't have sketches getting upset when placed features removed or updated.
I hope this helps.
Curtis
Message 8 of 18
JDMather
I fooled around a bit (see attached).
Message 9 of 18
Everything you have sketched in a one go. The quality of your work is well above average. It is not possible for an average person.
Message 10 of 18
Q1) Sketch5 has a repeated dimension and is missing a Tangent constraint.
A1) I don’t know which is repeated dimension. Target is for fully constraint sketch. Importance of inclusive of Tangent constraint is yet to be learned.
Q2) Sketch8 has sick geometry (pink circle) that I assume was projected from a feature that was removed.
There was no feature was removed. EOP was moved to add features.
Q3) Did you remove a Ø.605 cylindrical feature or circle that existed earlier?
A3) There was no feature was removed.
Q4) I notice that there is no Sketch 3, or 6.  Did you use these sketches as parents and then delete them?
A4) There were sketches deleted in the process of finding easy way to do a sketch. These deleted sketches were not used as parent.
Q5) I notice that there are about 20 missing parameters.
A5) Target is for fully constraint sketch. Missing parameters concept is not understandable.
Q6) Did you have a bit of trouble getting this far?
A6) In my 1st attempt I realised that there were problems in that particular method. Therefore I selected 2nd method.
I didn’t find fixing this problem in other ways was a problem. But I want to know why moving EOP was giving trouble.
Message 11 of 18
in reply to: Mark.Lancaster
Kudos is much appreciated if the information I have shared is helpful to you and/or others
I have a long time confusion. Is this added by you or automatically comes?
Message 12 of 18
CCarreiras
Answers will follow...
CCarreiras
Message 13 of 18
JDMather
 .... But I want to know why moving EOP was giving trouble.
Given that you can't find the repeated dimension (see image - I moved them closer together) - I am not sure you are ready for geometry constraints (like Tangent) or manipulating the EOP.
There were only 3 dimensions in the sketch?  How is it not possible to recognize the repeated dimension?
Message 14 of 18
in reply to: Curtis_Waguespack
I wish to know what Break Link is doing behind the screen.
I follow your advice of 1st simple sketch and building on that and it is working well. Before I have to struggle many hours and many steps to get fully constraint sketch, now I can get it with a couple of steps. Thank you very much for introducing simple method. I have given a name for your method KISS (Keep it Simple and Stupid) approach.
Message 15 of 18
CCarreiras
Now, keep it simple..... is stupid??!! wow!!!! so wrong...
if you want to keep the KISS with some sense, try Keep It Super Simple, because stupid doesnt fit here at all...
CCarreiras
Message 16 of 18
JDMather
Keep Inventor Sketches Simple
Message 17 of 18
Above average person keeping it simple is different from a stupid person keeping it simple.
Message 18 of 18
Curtis_Waguespack
 Hi fiatnm,
 >> I wish to know what Break Link is doing behind the screen.
So when we project geometry, a link is created and the projected entity ( in this case a circle ) updates when the original geometry updates. But when the original geometry is no longer available, the projected geometry is "orphaned". Inventor gives us an error, and allows us to fix the sketch. Using the Break Link option makes the entity (again in this case the circle) independent, so that it behaves just as if you'd sketched it, rather than projecting it.
Indeed the simple sketches method is extremely powerful, for beginners and experienced users both. When working in an office of professionals you are often required to update or modify someone else's work, and it can be very difficult to do when that work was created using sketches that contain geometry that controls multiple features. For that reason we prefer to see designs create models with the idea "how can model this so that someone else can update it quickly". Thinking about this as you model, saves time (and money) later.
You're quite welcome, but I should point out that just as I have introduced this to you, others introduced it to me. I worked for many years using AutoCAD and am very proficient in that software. In it we "draw" rather than "sketch" and when I began using Solidworks and then Inventor,  I was guilty of trying to draw complex sketches those softwares. Once I learned to use simple sketches, I was able to progress quickly learning the rest of the software since I didn't get stuck trying to create and modify sketches.
Smiley Happy I understand what you mean, as when we "dumb" down our sketches, it might make them seem less intelligent, since there is less information contained in them. But, I would say: Keep it Simple and Smart! , since when sketches begin to act stupid, it's often because the are not simple. Keeping them simple, keeps them acting smart.
Also, traditionally the KISS method means (Keep it Simple, Stupid!) , but in a professional business atmosphere the word "stupid" can be received poorly, offending others, and making them defensive, even when used as a joke, so we try to say (KISS = Keep it Simple, Sir!)
I hope this helps.
Curtis
Technology Administrators
