Entering Material Mechanical Properties from MatWeb Manually - Values???
barrettdent
barrettdent
I'm trying to create FR4 (flame retardant version of G10 or Garolite) in the Inventor Materials Library.  Inventor is asking for some pretty standard information like the Young's Modulus, Poisson's Ratio and Shear Modulus. Unfortunately MatWeb does not provide this seemingly basic information. Has anyone figured out how to extract useful (meaningful) values from MatWeb to feed into Inventor?
Mechanical Properties Metric English Comments
Hardness, Rockwell R 117117ASTM D785
Tensile Strength at Break 46.9 MPa6800 psiASTM D638
Tensile Strength, Yield 48.3 MPa7000 psiASTM D638
Elongation at Break 20 %20 %ASTM D638
Elongation at Yield 6.0 %6.0 %ASTM D638
Flexural Strength 72.4 MPa10500 psiASTM D790
Flexural Modulus 2.21 GPa320 ksiASTM D790
Izod Impact, Notched  0.801 J/cm
@Temperature -30.0 °C
1.50 ft-lb/in
@Temperature -22.0 °F
ASTM D256
 2.67 J/cm
@Temperature 22.8 °C
5.00 ft-lb/in
@Temperature 73.0 °F
ASTM D256
Gardner Impact 14.1 J10.4 ft-lbASTM D3029
I've taken the Tensile Strength, English values as Yield and Ultimate Stress Values under Tensile Strength in Inventor
But for the remaining values, I'm at a loss.
I'm working from:
http://www.matweb.com/search/DataSheet.aspx?MatGUID=fcbb32d6b39b4d59ae3f2b4a1bc1582f&ckck=1
TheCADWhisperer
Isn't Garolite a composite material?
Given that Inventor analysis is limited to isotropic materials - why do you need any property other than Density in Inventor (or are you going to be running analysis in some other program)?
